I got the kit and will assemble it this week, but look forward to tweaking this wthout breaking the bank. Apart from Voltseconds link found in these forums, there is no real list of what all tweaks have been done, but from what I can gather they are :
1. replace UTK transfomer with Hammond 1608 or 1609
2. replace capacitors maybe with Auricaps
3. replace resistors with Vishay ?
4. snubberize (what ever that means)
I guess anything can be replaced with any other equivalent value, but how much of this can actualy be heard as making a positive improvement ? This is my first tube amp diy kit and to be honest do not understand what and how it all works together but I do know how to desolder and solder.... so having said that from what I heave read, replacing the transformers would be the easiest albeit more expesive tweak" but certainly something i am capable of.
Do you agree or suggest a better approach ?
Another question before I start assembling : whats the safest method to discharge transformers, capacitors and is that the only thin I need to be concerned ? Or do you recommend I get the Hammonds first ?
Neville
Neville
K-12g
For that particular amp, the greatest improvement, in order:
1- Power and output transfos
2-Volume pot
3-Capacitors
You can make one change at a time and later with ($) make another mod.
Dont be afraid to try anything, but be careful, you're dealing with high voltage!!!
Good luck.
2-Volume pot
3-Capacitors
Good luck.
I have already been thru that post but did not find anything that helped with . The pdf file about discharging just got me more confused.
K-12
Hi Neville,
Look at this thread and search that board for about any Question you may have on K-12/K-502.
Refefer to "EWBrown" he knows about everything on that amp.
http://diytube.com/phpBB2/viewtopic.php?t=416&highlight=k12
Hi Neville,
