Finally got the first channel of the DOZ working(problems I was having were due to a transistor not working as it should 🤐 the damn thing could just have stopped working and saved me hours of troubleshooting), and though I haven't made any measurements yet, the sound is really good, fluid and not fatiguing at all. I expect to post some pictures soon. I hardwired everything using perforated boards so it still has a rats nest look into it.
Though I know Elliott also has a DOZ project for headphones, I'd very much like to keep the headphones option on the same amp. Is there an "easy" way of doing it? As far as I can see from the schematics the only differences are on the output transistors, and the extra output resistors. As for the resistors, I can use a switch to change between the headphone/normal amp mode. Is there a problem in using the 2n3055 transistors with the suggested 300mA of quiescent current?
Tiago Rodrigues
PS: Just a word of appreciation to Rod Elliott for sharing his great designs and knowledge.
Tiago Rodrigues
It'd work, but ...
Thanks for the link Fredie, I understand the solution presented in the link, though I think it's an awful waste of power(not to mention the gratuitious heating) drawing 1.5A continuously while using the headphones unnecessarily.
Still, it may be a fair solution as backup, if i can't manage it in a more efficient(economic) way.
Regards,
Tiago
Regards,
Tiago
tiagor said:Is there a problem in using the 2n3055 transistors with the suggested 300mA of quiescent current?
Olá Tiago!
Of course not...you only need use a heatsink and some thermal compound!!
Um abraço! 😉
