Adding DI Transformer
I am building a Champ copy tube amp and I want to add a DI transformer. My question is on placement. Do I put the Jenson jt-db-e DI Transformer directly across the 6V6 tube, capacitor coupled 0.47uf, like a parafeed transformer? I want to get the amps sound going to the mixer.
If you want to NUKE that tiny Jensen transformer, go ahead.
I doubt it can even stand Speaker voltage, go figure.
I would not feed it more than 1 volt.
Use a voltage divider across speaker out, think 470 ohm series + 100 ohm to ground.
Wire Jensen transformer primary in parallel with 100 ohm resistor.
And never ever leave OT secondary unloaded; at least use a 4 or 5 ohm resistor, 10/15 W.
