Adding a pentode input to a guitar amp
How would you connect this:
To an amp like this:
what i would like is to have both flavors, like triode and pentode (sort of a Champ 5C1 overdrive) independent inputs onto this amp which is already very clean. I have a hole for an extra volume control.
yes that's the easiest way, so easy I didn't even consider until now 🙂 I will try it for sure, how about bypassing the tone-stack altogether connecting the .02 out of the 6sj7 to the wiper of the treble, or even to the concertina .022 ? what would you think if you actually see something like that being done to an amp 😱
You can "bypass" much of the tone stack via a 25k+ pot replacing the 6800R. Setting the new Mid Pot at max would be close to bypassing. Or a switch on the 6800R but it will "pop" if thrown when running. Or a switched added 7-20k resistor in line with the 6800R. I've used all those.
Pentode-tonestack-triode is already more gain than standard.
Pentode-tonestack-triode is way more gain, a monster.
Pentode-concertina is less gain than standard, hard work.
But I dunno. Any of these may be "your amp". An hour of hot solder may say more than days of bench-racing.
Wouldn't do that. ... LAAOOUUD plop ...
I said it was simple. Won't kill the guitar amp/speaker. May scare the dog.
I want him to try-out the pentode, see if it worth the effort, before complicating. I know many people are trying pentodes. My impression is that just because amp X is cool and amp X has a pentode, doesn't prove much. Pentode is more complicated to set-up clean, and wickedly complicated to set up "tonefully". When/if he gets as far as A/B testing, for-sure he will want a less POP setup.
