I'm trying to feed my AV component through my Yamaha AV amp into a Gainclone. I would also like to use the tuner. My cd feeds directly into my GC which has a source switch. There is no pre-out on the Yamaha, only a CDR out(sim to tape?) The problem is it doesn't go through the volume control so I have to adjust volume on the Gainclone manually. Is there a way to add a pre out and esentially use the receiver as a preamp, and if so where in the circuit (theoretically) would I tie in. I'm thinking just after the volume knob. Also, will I run into impedence problems etc. Has anyone done this before?
Any and all input welcome.
David
David
David you can buffer your speaker outputs to feed the gainclone or you could use your headphone jack
JOE DIRT® said:David you can buffer your speaker outputs to feed the gainclone or you could use your headphone jack
Great idea Dirt, the headphone jack didn't occur to me
No major surgery after all.
David
I kinda figured you did not want to mod the receiver....so thats your best way....either option works well and if you want to get fancy just add rca jacks on the back wired up to what you want inside
The headphone jack on most receivers is just a 330 ohm resistor off the main power amp. It is intended to drive low impedance headphones.
Without a low impedance load, no attenuation will occur.
Terminate the headphone jack with 33 ohms and you should be fine.
The temination resistors could be built in to the cable plug, or in the CG chassis.
You mean GC chassis right...and yeah...the 33 ohm thingy MUST be there...or at high volumes...on the recieber...the sound will distort badly...
djk said:The headphone jack on most receivers is just a 330 ohm resistor off the main power amp. It is intended to drive low impedance headphones.
Thanks all simpler than I thought Iwas going to be.
What did you think it was gonna be?? hehe...couldn't waste a change to joke here...when you have finished...tell us what it sounds like ok?
- Addind a pre out to receiver?
