Bought it on eBay for a portable boombox im doing but accidentally took the one without aux input, just bluetooth, so i was wondering if there is any way to add an aux input to it and how to wire it, i've been looking for diagrams but haven't find anything yet. 😕
This is the exact board.
Thanks in advance 😱
Thanks in advance 😱
I would say yes, its do-able but only for an experienced tech. You would have to find the audio feed to the TDA7492 and physically cut into that feed to isolate it. You would also need to ensure that any biasing requirements on the input pins were retained. A switch could then be connected to select between the original configuration or an external input.
That 8 legged IC looks like a 5532 ? The output from that will likely go to the 7492 so that would be a place to start looking.
There was discussion about the one with the 3.5mm jack. It seems that is a combined mic/headphone jack. Any input is likely to be mono. That topic may have moved on but that was the last I read of it.
J.
J.
J.
Didn't know it will only work only mono, then it's useless to me 🙁
Since i'm not a electrical expert then i'll stay away from mods 😛
