I am searching for a chip that can take analog input and maybe S/PDIF inputs also and convert it to a single S/PDIF ouput?
http://www.esstech.com/PDF/SABRE32 ADC PF 081218.pdf
we need someone to sign NDA and order it from UK , once someone starts groupbuy im definately in !
SmellOfPoo said:
That is the manual for the ADA24 DAC. Here is the product page for the AAD24 ADC......
http://www.elv.de/24-Bit-Audio-AD-Wandler-AAD24/x.aspx/cid_74/detail_10/detail2_14798
and the manual......
http://www.elv-downloads.de/service/manuals/AAD24/AAD24_KM_G_050912.pdf
The ADA24 uses CS5340 + CS8406.
tritosine said:http://www.esstech.com/PDF/SABRE32 ADC PF 081218.pdf
This is a response to an email I sent earlier to an ESS distributor here in the states......
Hello,
The ES9102 pricing has not yet been finalized. The ADC will be sampling later this quarter.
The ES9012 DAC sells for $48 per unit in quantity 100.
Best Regards,
Bryan Shaw
Shaw Electronics LLC.
(281)507-9764
My fault 🙄 Thank you for correction!
- Digital Line Level
- ADC with S/PDIF output
