Any advice for an AD797 differential to single ended output stage with a gain of 9X for balanced voltage DAC?
I am planning to replace the DCX2496 output stage with AD797 opamp.
Any schema to have a gain of 9x and stable?
The dac is AK4393 with balanced voltage output
4580
I know the AD797 is sensitive to PSU and can oscillate, don't think it can be a drop in replacement, at least it needs some caps to tame it (compensation)
will use only the first op amp stage and take SE output before the mute transistor
