AD1865 Query
I'm using a board that comes as standard with Vout from the DAC chip. The board also has I out directly from the DAC chip. However, if I connect the I out to my valve output stage there is only a very faint signal. My question therefore is: do I have to remove the V out components, resistors etc to use the I out?
