Hello everyone..
I am building a little pre-amp and tone control, but i am having some problems.
I wanna set the gain higher, but can't figure out which resistors to change, and what value.
I am also pretty shure that i have done something wrong, specially because there is no signal ground connection un my circuit. The reason for this, is that the sound is almost gone, when i put ground on.
The tone control is somewhat working right now, but i would like it to be done right, and my first priority: get the gain up!
If someone can help me out i will be very happy!😀
This is the original schematic:
This is how i have soldered it on the board:
This is a Baxandall active tone control. The mid-band gain is fixed at 1, so you can't increase it. Sorry.
Once you get it working, you ought to add high value resistors at the input and output so that C2 and C8 have some DC bias. 100-470K should be fine.
I don't understand. The -ve supply is also signal ground in this circuit.I am also pretty shure that i have done something wrong, specially because there is no signal ground connection un my circuit. The reason for this, is that the sound is almost gone, when i put ground on.
Thank you for the fast response, i have the schematic from the site below. In the bottom there is a text, i thougt was about gain (quoted below)
41Hz Audio - Simple tone-control. might be
"The opamp can act as a pre-amp too, of course, with the right feedback.
(play with some resistor values, but NOT with R5/R6!)"
Also, i don't understand the ground thing either, and don't know where if i should just let signal ground go directly to amp or someone can solve the mystery.
The circuit is shown to work off of a single ended power supply or 9 volt battery. The + 741 input is set for 1/2 supply to be able to do this. If using a symmetrical supply this point becomes the ground for power and signal.
hmm, from what I understand the active feedback is slightly different from the passive
only one cap needed in each place, instead of two
dont know if its 'essential'
btw, active feedback uses only linear pots, where the passive needs to be audio logs, to set the linear midpoint right
and like said previously, the gain is only available for the tone control boost settings, or else its just a unity gain buffer
Of course you can use an opamp to get gain, but that would be a different (simpler) circuit.CasperSort said:i thougt was about gain
I don't understand what it is you don't understand. As I said, signal ground in this circuit is the -ve supply rail. What is the mystery? Connect input to input, input ground to -ve. Connect output to output, output ground to -ve.CasperSort said:Also, i don't understand the ground thing either, and don't know where if i should just let signal ground go directly to amp or someone can solve the mystery.
well, you can get midband gain from the IC instead, if you configure it like passive baxandall, and not feedback
but then the tone controls will have attenuation function only
😕 I thought the feedback baxandall should be inverting to function properly
ups, sorry, ok, -ve = - supply voltage
whatevr, this link might help you http://sound.westhost.com/dwopa2.htm#baxandall
I will try to play with it when i come home, and read i bit deeper in your answers.
Until now thank you for support.
A new question: i have an extra ic tl072, could i put this one after the tone-control to get some more gain?..
Basically, yes. For noise reasons, it usually is better to place a gain stage in front of the tone control, as in this design.
Checkout
http://harrisonaudiolabs.com/images/Preamplifiers/P1/P1sch.png
Also on your posted pictures. You need to place the high frequency stabilization capacitors close to IC.
- Analog Line Level
- Active Tone Control and preamp. Need help urgent!
