Running from a Hypex FA123, would it be possible to get cardioid pattern with this setup? Similar drivers on front and back, one on the back in reverse phase. Is it smarter to run the drivers on the back crossed only to reproduce bass frequencies? Hypex would allow adjusting negative woofer level for more or less cardioid effect?
Monopole+dipole=cardioid if i understand correctly.
Yes, but only after the dipole has been equalized to flat and the SPL of monopole and dipole on axis is the same.
Summing a monopole and cardioid can work OK at low frequencies, but at higher frequencies (well below the crossover point to a tweeter) the pathlength between sources causes problems.
Thanks, so playing around with this setup can work. Takes alot of testing and tuning, but is possible. My thought was to drive one woofer at front to crossover point other woofers would cross off at baffle step frequency. Just trying to get cardioid in bass territory to make it suitable for close to wall positioning.
Rule of thumb is: quarter wavelength distance between front and rear drivers, quarter wavelength delay + polarity flip on rear drivers. You can use a lower lowpass on the rear drivers, but keep in mind the relative phase response has to be controlled.
How close? The rear drivers need to be able to radiate properly for it to function as a cardioid. Why not use a monopole close to the wall?Just trying to get cardioid in bass territory to make it suitable for close to wall positioning.
Do you mean a build like Verity Audio with bass on back side and close to wall and floor? Then just eq it as i could have a constant distance with the wall? Yes that could do it also.
No sorry, I mean why not just use a monopole, single forward firing bass driver. Why do you want cardioid bass, what is your set up?
- Active multi driver cardioid speaker?
