Active DSP with 3x XH-M562 for Portable Boombox
I've read through articles for at least 10 hours now but I've still got a question about building an active DSP 5 channel boombox:
If the DSP (adau1701 + PCM5102 DAC for extra channels + ESP32 dev board) controls the crossover for each channel of audio feeding into the drivers, could I use 3x XH-M562 for power? I believe based on my reading that the more 'complete' TPA3116d2 boards are not needed as the DSP will be outputing prefiltered audio signals. Is that correct?
Otherwise I'd be going with one of the '5.1' TPA3116d2's
Thanks!
P.S. Would I connect a preamp poteionmeter to the DSP input or the TPA3116d2 for volume control on the boombox?
