WARNING: Tube/Valve amplifiers use potentially LETHAL HIGH VOLTAGES.
Hi - as class A se amp output they work well at around 20mA quiescent into 5k load. Surprising if you look at the role they were designed for in early television.
Worth a try and can be used as input/ driver as well.
