Offering only 1 bass driver. This is woofer, could be used in many different sealed or vented designs. High excursion, very low distortion. Very little used, purchased new from Acoustic Elegance a few years back. The TD Series woofers are low distortion, high Xmax, wide bandwidth, bass drivers designed for sealed or vented enclosure applications. The TDS use a 2 layer round wire copper coil for higher Qts. They are typically the option chosen for sealed box applications and larger vented box applications. They are often used in larger floor standing speakers. This is heavy driver.
Price $ 350.00 plus shipping
Specs:
TD15S-8ohm
Fs: 22.8Hz
Qms: 3.87
Vas: 467 L
Cms: .45 mm/N
Mms: 108 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .41
Re: 5.3 ohm
Le: .3 mH
Z: 8 ohm
Bl: 14.1 T/m
Pe: 500W (cont.)
Qts: .37
1WSPL: 93.4 dB
2.83V: 95.11 dB
TD15S-4ohm
Fs: 22.8Hz
Qms: 3.87
Vas: 467 L
Cms: .45 mm/N
Mms: 108 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .41
Re: 3.5 ohm
Le: .3 mH
Z: 4 ohm
Bl: 11.5 T/m
Pe: 500W (cont.)
Qts: .37
1WSPL: 93.4 dB
2.83V: 96.91 dB
Suggested Enclosures:
3.0-6.0 cubic foot sealed
5.0-8.0 cubic foot vented
Specs:
TD15S-8ohm
Fs: 22.8Hz
Qms: 3.87
Vas: 467 L
Cms: .45 mm/N
Mms: 108 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .41
Re: 5.3 ohm
Le: .3 mH
Z: 8 ohm
Bl: 14.1 T/m
Pe: 500W (cont.)
Qts: .37
1WSPL: 93.4 dB
2.83V: 95.11 dB
TD15S-4ohm
Fs: 22.8Hz
Qms: 3.87
Vas: 467 L
Cms: .45 mm/N
Mms: 108 g
Rms: 4 kg/S
Xmax: 14 mm(peak)
Xmech: 20 mm(peak)
Sd: 855 sqcm
Vd: 2.4L (p-p)
Qes: .41
Re: 3.5 ohm
Le: .3 mH
Z: 4 ohm
Bl: 11.5 T/m
Pe: 500W (cont.)
Qts: .37
1WSPL: 93.4 dB
2.83V: 96.91 dB
Still available? What's the reason for selling, on paper this looks like the best sealed woofer ever.
This one was sold. I have recently moved from SF to LA and during my reorganization in garage, one driver was damaged. At that point I decided to sell another one that was in a perfect shape. Yes those are great drivers, I could definitely admit that.
It would cost more than buying a new driver. It fell on concrete so the massive magnet got out of alignment. Cone was fine. I ended up giving it for free to a friend of mine for a product demonstration purposes.
