Ok...
...from other posts I've learned that using multiple drivers results in an increase in SPL (through acoustic coupling) especially as frequency drops.
So, if I choose to use say 2 or 4 mid/bass drivers in a TMM or TMMMM configuration, then I'm going to need a relatively more efficient tweeter to make up for the increase in low frequency SPL from the multiple mid/bass drivers?
Correct?
Mos
Correct?
Mos
Depends on the connection. As a series pair, the sensitivity of two Ms will be unchanged from a single one. In parallel, you'll pick up 6 dB of sensitivity.
