Acoustat loss of mid and high frequency
Hi My RoomEQ tests indicate a loss of mid and highs (drops about 15 db. Whilst this may be because of the room - I doubt it would cause this level of loss.
The acoustats are about 900 cm about 35 inches from back wall.
Can this be attributable to them not having been washed? or other suggestions?
What Acoustat ??......Ck the bias!.....if it too low you well lose output...an can kill stepup interface tranfourmers...
an other parts.....lot of info here on Acoustats.................
lot say wash the panels.....I have done this...but well never again
some coating always come off.....most panles are 30 years old now..
Look if the panels are black from crud....that's diff...but I never seen this.......most of the drak water is coating.....not crud....less coathing less output.....good luck
