If the crystal will be used in a DAC 1000 ppm is good enough and certainly 200 ppm.fmak said:Can someone please point to a source of at least 50ppm 11.2896 crstals? Not XOs. Ideally in UK
Re: Re: Accurate 50ppm Crystals
No, this prevents narrow pll jitter reduction devices from locking.
peranders said:If the crystal will be used in a DAC 1000 ppm is good enough and certainly 200 ppm.
... so you want to attach a jitter eater but where. Better than 50 ppm seems very unpractical for one thing.
Re: Re: Re: Accurate 50ppm Crystals
You are assuming that the incoming signal is exactly 11.2896 MHz, which is rarely the case. It is not uncommon for it to be off by 200 ppm or more.
- Digital Source
- Accurate 50ppm Crystals
