I will get a Accuphase P300X for rapair. The main relay is not working any more. Therefore we want to replace the relays.
Main Relay: Omron MY4-02-US-40L DC 48V
Replacement found on Digikey:
Blocked
Speaker Relay: Omron LY2S-US DC 24
Digikey link
Blocked
Digikey was trying to help us, but the don't know what -US- means.
here a nice link:
accuphase p-300x
many thanks
Dieter
Blocked
Digikey link
Blocked
here a nice link:
accuphase p-300x
many thanks
Dieter
I am probably naive on this but why are your first two links marked "blocked " when I have access to both ?
Also your "accuphase link " takes me to a "Chinese looking website " which is marked --for me as "unsafe " --now that should be marked blocked not the first two which took me to Digikey (USA ) with which I have done business with in the past .
amp8.com is a japanese site (very cool stuff).
my links goes to Digikey Germany. Why they are blocked ???
Available in Germany as the seller is German:
Replacemant For OMRON MY4-02-US-40L 24VDC Speaker Relay | eBay
For speakers and mains voltage purposes you need silver based contacts, preferably bifurcated. Seems to be the case but check all details.
https://docs.rs-online.com/3c0d/0900766b816b96d4.pdf
Ask DIY Audio there must be some reason as that is what is marked on your post.
On the UK help website I was on a moderator statement was issued sometimes posters tried to post "bad " websites or links so I just took it as a shortened reply/answer/statement.
Jean-Paul,
many thanks !!!
Dieter
Hallo Dieter,
auf der Suche nach Schaltlänen für den P300x,
bin ich soeben auf Deine Frage gestoßen,nehme zwar an, dass Du die Relais bereits ersetzt hast, aber folgende hatte ich als Ersatz gefunden : 3 Stück Ersatz für MY4ZN = Finder 55.14.9.048.000, Ersatz für GV2-2 = OMRON G5V2-24VDC, Ersatz für LY2-US.... = OMRON LY2-N-D2-24V !
Besten Gruss
Angelo
PS Falls Du Schaltpläne für den Amp hättest, wäre ich sehr interessiert.
Besten Gruss
Angelo
Please post in English as per the forum rules.
Hello Dieter,
in search of switching boards for the P300x,
I have just come across your question, suppose that you have already replaced the relays, but the following I had found as a replacement: 3 pieces replacement for MY4ZN = Finder 55.14.9.048.000, replacement for GV2-2 = OMRON G5V2-24VDC, replacement for LY2-US.... = OMRON LY2-N-D2-24V !
Best Greeting
angel
PS If you had schematics for the amp, I would be very interested.
- Accuphase P300X Relays
