AC to DC
Hi, i have a question . How should i connect transformer and bridge rectifier and also 4 capacitors ?
Transformer is 42v-0-42v
Bridge rectifier is 35A and 1000v
Capacitors are 4x 10,000uf 80v ( or should i consider upgrading from 80v to 100v ? )
Powersupply is gonna be used for audio amplifier . I havent yet decided what amplifier im gonna build . But around 250w per channel .
Thank you 🙂
There is an extensive page on shipping from ESP that explains shipping. You will get access to documentation on assembly, setting the bias etc.... I sourced the parts myself, that adds to the fun.
If you want a more plug and play option, you could source some pre made boards from the interweb. Remember your rail voltage from a 42V-0-42V AC transformer will be approx 1.414 * 42 or +/- 59V DC the boards for this voltage range are slim pickings.
