I wrote this review with the non-techie newbie in mind. Many of you will find it amusing. And it will become quickly apparent that I’ve worked in Marketing…….
Aural Ecstasy – The VTA ST-120 Power Amplifier
In today’s cyber marketplace, it is almost a given that “seller feedback” is expected to be instant and automatic hyperbole – but it is rare that such extravagant praise is actually warranted. In the case of the VTA ST-120 power amp, designed after the venerable Dynaco ST-70 warhorse, but with completely upgraded and improved circuitry by Tubes4HiFi’s Bob Latino, and lovingly built for me by William Gratrix (forum name “Audiobill”), the expected superlatives actually pale in comparison to the experience I am having with this fantastic and affordable piece of audio equipment.
In short, the ST-120 is a miracle. The sound quality, versatility, and value of this unit is comparable to amps costing four times as much. And affordable options, such as a protective 17 second time delay relay (to soften the power-up surge), a high-quality stepped attenuator which allows one to tailor input levels to a preamp optimum or even forego a preamp altogether, and available alternate output impedance taps (choose two of 4, 8, and 16 ohms) make this amp, delivered to my door within two weeks of my order, ready to plug-and-play with a well-selected set of eight fine tubes, a steal at $1732.
At 60 WPC, the ST-120 can power even moderately inefficient speakers to satisfyingly punishing levels in a reasonably modest listening space. I have a set of notoriously power-hungry B&W Matrix 803s which are perfectly served by the VTA. {N.B. Older B&Ws will be found to sound much more controlled and smooth driven by the 4 ohm taps!}
The standard-issue triode/ultralinear switching capability allows one to effectively alter the size and shape of the stereo image in a way which must be experienced to grasp. Triode mode will sound more intimate and laid-back to most ears, like a small club environment, while ultralinear mode might be likened to moving to arena-sized or concert hall ambience. Source and mood will dictate what sounds best at any given moment. It’s a great feature.
But how does it sound? Well, the only way I can tell you is to state that the ST-120 is the closest thing to the ideal of “a wire with gain” that I’ve ever heard. Given good-quality sources, well-matched speakers, and a well-designed listening room, you can expect your gear to disappear, leaving nothing between you and your music. It doesn’t get any better than this, folks. Bass is naturally extended and as solid as your speakers can deliver, while highs are uncommonly detailed and smooth without any sense of harshness or fatigue. In short, miraculous.
Several other things to note: this unit runs cooler than any comparable amp I’ve ever used. Top temperatures at a “full gallop” will climb no higher than 200F at most (measured by laser therm on the output tube plates.) Power transformer was measured at the same time at only 130F. This means that you are getting top-flight sound delivered efficiently by components which are being only conservatively driven. This amp is built to last, and further, it is designed to ensure that all tubes and components are going to remain well within proper tolerances for much longer than one might expect.
It is worth noting that you can expect the sound of this unit to improve in subtle ways over the first hundred or so hours. I waited four days since I first powered it up to write this report. I’m not even close to getting the “full monty”!
Add to this the incredibly responsive customer service that you can count on from both Bob L. and Bill G., who will patiently answer your questions – even dumb ones – and the fact that, should you have even a modicum of ability with a soldering iron, the amp is available in kit form for as little as $909, and the experience of buying a superb power amplifier which truly deserves rave ratings is yours.
This is DIYaudio. Even our newbies are usually at least a little bit techie.
Sorry, I only read your first three sentences!
Was this an exercise in creative writing, or will you be progressing to DIY in due course and wanted to meet us first?
don;t be such a self righteous pompous ***!
We all start somewhere. This guy is obviously new to the world of tubes and is very impressed with his first venture.
No doubt, and hopefully, he'll progress into DIY with tube audio gear, and will find a whole new wondrous world out there!
What we don't need is school yard sniping and bitching!
He's a retired physicist. Comes with the territory...😀don;t be such a self righteous pompous ***!
DF...sorry, low hanging fruit..
Montanaway, I suspect you may have read his post intent incorrectly..
jn
Don't know never got that far...
M. Gregg
jn
I tend to get pretty pissy about such comments though, no matter what their intentions are.
All of us had a 'day one' when we knew nothing about tubes and electronics, and evolved from there.
What newbies need is encouragement, our help and support, so ensure they too can enjoy the magic of tube audio as we do.
It always seemed to me before that this forum accepted building from someone else's plans or kits fair fodder under umbrella of "D I Y." Perhaps the unpardonable unwritten rule that was broken here was Kentley's getting help with the build.
Perhaps DF' intends a particular style of (dry?) humour that is often hard to detect by a stranger, a nubie on the forum separated also by across the geographical and cultural distance. If so, I didn't hear it either, nor did Montana. I thought DF's response came across as a heavy-handed and unwelcoming smack in the face to enthusiastic newcomer to this corner of the hobby.
I hope I'm hearing it wrong, and is was not your intent to be unkind.
Reads like an infomercial to me; ''the following program is a paid advertisement for'' etc etc.
Amusing? How so?
How do lists of specs,options,perceived performance and wonderful service (all 26 lines of it) not constitute shilling?
Amusing? How so?
Must be the sales dept sent here by mistake . WOWThis is DIYaudio. Even our newbies are usually at least a little bit techie.
It absolutely does, in fact, encourages it. It's the reason for the forum's existence.
It's not clear from the description that this was something built or bought- I *hope* the former!😀
Geez, I didn't mean to restart the American Revolution!
Just a few points:
1) I posted this piece not as an advert. A member of the USA based Dynaco Tube Forum suggested that I reprint it here.
2) The real point some of you are missing is that the gentlemen mentioned in my piece, Bob and Bill BOTH started out just like you - as DIY hobbyists. The fact that they are able do something they are passionate about AND parlay it into a business venture speaks well for them, IMHO. Perhaps those critics who demean them by mocking me could learn something from their efforts.
3) I will refrain in the future from diverging from "The Way" here. Can we talk about tube rolling now?
No hard feelings, guys. And thanks to those who jumped in to make a point on my behalf. No one has insulted me. They've merely tried to defend their territory. But no one need feel threatened. Enjoy your tubes!!!
Just a few points:
Good form Kentley.
Hey, since it comes in kit form as well is there a schematic. This would interest me.
Thanks!
Thanks!
Sorry for causing offence. I was genuinely puzzled why someone would want to start on DIYaudio by writing marketing-style blurb for an amp he had bought. Two thoughts crossed my mind:
1. Is this advertising? This happens quite often, but people are usually found out quite quickly.
2. When I was a newbie I kept quiet, apart from asking lots of questions and reading lots of books. Maybe I was too shy?
"The Way" here is DIY - the clue is in the name. Those who can't do DIY may resort to tube or cable rolling as a substitute activity.Kentley said:3) I will refrain in the future from diverging from "The Way" here. Can we talk about tube rolling now?
And there was no WWW to venture onto 😛
He's from across the pond..Nobody understands their humor..Perhaps DF' intends a particular style of (dry?) humour that is often hard to detect by a stranger
But there were velociraptors.And there was no WWW to venture onto 😛
jn
jn
Aye, and we had to walk to school in the snow, uphill both ways!
You had a school to go to? All we had was a dead tree where we were beaten with a cane for arriving early or late.
- Tubes / Valves
- A tube newbie's review of the VTA ST-120
