Here is trick to connect graphic eq to a power amp (with phono input)which has no jumper. Will not work for other high level inputs that are connected to the source selector.
Set the record source switch to phono.
Connect your eq input to record out and feed the eq output to one of the high level inputs, say Aux and select the same as source on the amp.
My friend has a Technics SU VX500 and was successful in using his graphic eq on this amp without reaching insides.
Gajanan phadte
Gajanan phadte
very nice ....you reminded me the trick i used when i was working around 1985 in hifi installations when people still used equalizers .....
