a shift register fast enough for AD1865?
Im bout to build a CS8414 + AD1865 based project, but want to tackle the interchannel delay problem with an 18bit static shift register.. The problem is I cant find anything fast enough (either clock rate or latency wise). Can anyone here suggest any quick ICs to do the job?
Cheers
Re: Re: a shift register fast enough for AD1865?
rfbrw said:
Thanks for the reply, the links are very helpful. It was more the propagation delay (after 18 stages) than the clock rate that was a problem. I dont want to delay the clock pulses half the time to compensate for the propagation. I guess the notion of finding an 18 stage static shift register with a total propagation delay comfortably under 30ns might be "radiculous", but my search skills suck 🙁
