I was poking around the web trying to figure out what to do about a time on delay for the PSU of my linestage and I came across this:
http://www.amperite.com/Uploads/Ballasts.pdf
I wonder if this could be used as a CCS in a tube amp? Interesting.
Gavin,
IIRC those where meant for heater circuits among other things, not high voltages.
Cheers, 😉
Gavin,
Cheers, 😉
Hi Frank. I figured as long as you didn't drop more voltage across them than they are rated for you would be OK. Just something I found while poking around. You would have to be careful when biasing the power tube though. Cheers
These where sometimes used to drop voltage in series connected heater strings but I have seen them used in high voltage constant current circuits also. If I remember correctly they consist of a plain iron wire in hydrogen gas. They have not so high Ri and the current regulation is very slow so I dont think they can be used as CCS in an AC circuit.
Regards Hans
Regards Hans
