As above
After a bored night the amp below arrived to use as a simple boom box type project for the garden, idea is to use a decent power supply and this amp to make a boom box type device to use in the garden.
Has anyone got any instructions or know where the inputs go??
Will be quite usefull
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281641119858
Ah, ok
On the supplied unit I actually have a terminal block soldered in which only allows for two wires. There are no markings on this.
On the rhs next to the single pot there is a three way connection, marked input 1, input 2 and gnd. Even though the plug isn't supplied could this be the input. PCBs is supposed to be a stero unit
Ebay listing says 18v to 32v so possibly not, might just work or under-voltage protection might cause shutdown. On full voltage at max stated output 80+80+160W = ~ 10Amp supply.
If you are handy at hacking things and have some old PC supplies knocking around, use 2 x 12v ATX supplies in series (you need to lift the PCB ground of one of them to avoid a short).
Hello RUSSC
the seller of the amp has this on eBay which he suggests is suitable for the amp, only issue is that it works of 12 volts.
If I get this unit what rating of 12 v supply will I need. I have a 12v, 5 amp jobbie knocking around, will this be enough
I now see why it pays to do some research as the power supply is or proving to be difficult if I don't go down his route
Link to power unit below
http://pages.ebay.com/link/?nav=item.view&alt=web&id=281641119141
- Class D
- A moment of madness
