Really digging the tapped horn idea.
in terms of extension to 20 hz can a small driver 8" go that low in a tapped horn?
heres the parameters:
would like 20hz
will trade some efficiency for extension
low cost driver <$100
can be a tall single fold horn to perhaps match tall fr blh that may be built as well.
current speaker, DM302 -6 at 59hz per: B&W DM302 loudspeaker Measurements | Stereophile.com
current amp 12x2 el84 tube integrated
stereo subs prefered
would like 20hz
For extension to 20hz the path length needs to be long, so expect a much larger cabinet than you would for a 20hz BR cab.
Single folds are quick and easy to both simulate and build.
I'm sure bjorno will chime in with some data on the T-TQWP
Hi Etocynned,
Look through this thread, it shows about the maximum you can get out of 8" drivers:
http://www.diyaudio.com/forums/subw...ped-horn-th-spud.html?perpage=25&pagenumber=1
Regards,
Regards,
