A horn for a coaxial speaker
Hi!
Merry Christmas!
I wanted to share that I just built Bill Fitzmauritz' s tuba 30 horns and I am very pleased with them, they sound great. Great horns.
Now I am aiming to build a horn for a top.
I have BMS 12 c262 coaxials on my archive, I calculated that the 60w compression driver delivers more spl than the 12", so I figured if I build a small horn for the 12" then they would mach. The horn would be 200hz to 1800hz. The question would be how would the compression driver act?
A
There are some port models out there to shorten your search. I'm mulling over something similar, but end up with a VERY large cabinet with the horn perched on top.
Sent from my Nexus 6 using Tapatalk
These look very good, I would love to have something like this for my room someday 🙂
This is what I thought actually. I was allready looking around the net for some horn plans from PA and they look very similar to these horns.
I like horns in general and I like how they look. Even If a horn would give the speaker a 3 db extra it would be worth it.
A small sealed chamber, cross @ 200hz, 400w rms + a mid sized horn. what do you think?
My intent is to control directivity, with higher efficiency 'mid' Woofers. My current horn reaches quite low (around 700 Hz) the hope is to reach from 40Hz up to 700 Hz which has proven difficult.
I'm also mulling over the Onken enclosure, which will be simpler to build. It's purely theoretical, at the moment.
