A few questions before I begin on the SSE
Hi All!
First off, let me say that this forum is super helpful as it's chocked full of information and data.
I have a few questions that I was hoping folks could answer before I get cracking on the Tubelab SSE.
1. Choke. I am leaning toward using a choke. Is this choke sufficient or overkill? Fixed Hammond 193J 10H 200MA.
193J Hammond Manufacturing | Mouser
I do not plan on using the amp with very sensitive loudspeakers.
2. What gauge and type of wire do folks recommend using for spots where I will need to jump two points (e.g. solid state tube rectifier switch (SW1), as I'll be rectifying by tube only) or where I'm adding something in like a supplemental power supply capacitor?
3. What values/tolerances are ideal for the supplemental power supply capacitor?
For a Power Transformer, I'm using an Edcor XPWR059 (Primary (Input) Voltage: 120Vrms or 240Vrms, 50/60Hz.) For Output Transformers, I'm using Edcor CXSE25-5K (Secondary (Output) Impedance: 6 Ω).
Thank you in advance for any help you can provide!
