Hi everyone, please help me with this Douk Audio U3 headphone amp or one of these days I'll hammer it. I've tried every way I know, but when I turn it on or when I insert the jack an annoying bump comes to the headphones and, since I have a wonderful (at least for me) Philips Fidelio H2HR I don't want to ruin it, so I'm doing my tests with a cheap Sony (9.90 € !!!). For the rest the amp works well but I don't know how to avoid this noise. I contacted the company and they gave me some advice that I already knew. What can I do? Thanks.
I assume you are using a standard 1/4" (6.35mm) TRS jack/plug for the headphones? These will produce a brief short to ground on insertion/removal and is just a detriment of the jack type. One thing I would do is measure the DC offset on the amp output (L-Gnd, R-Gnd). Any offset will exacerbate this issue.
Thank you for your quick response!
Yes, I always use 6.35mm jack, I really hate 2.5mm jack.
So there can be an offset at the output? Then I will never use it again! Tomorrow I will do some measurements.
The U3 seems to be a single-supply design. That makes a turn-on thump relatively hard to avoid - the output has to be brought up to ~1/2Vcc when powering up, yet at the same time you want good low-frequency response from it.
About the only thing you can do is looking for the Vcc/2 reference voltage divider, which should normally be an R/RC kind of affair with resistors around 10 kOhms, and make the capacitor as big as possible. Even that would only minimize turn-on thump, power-off is still relatively hopeless (and would also require a diode from midpoint to +Vcc to discharge the capacitor safely). This is a hard problem to crack without using some form of output muting e.g. via a relay, and the U3 is just a cheap little amp without the parts budget or space for such frills. It's still a good bit more fancy than my old BTech BT928 amp that used to retail in a similar price range 15 years ago.
Put your safety glasses on and give a good old beating.or one of these days I'll hammer it.
Now you'll be forced to buy something better, which shouldn't be all that difficult. 😉
jeff
You're discharging the output sound-coupling cap, which sits at 1/2 of Vcc, every time you plug AND unplug the headphones.
Output cap should have discharging resistor after it. I dealt with it with hamptone pre, it was needed for radford, and especially for last heaphone amp I built, designed by Hugh. I had click at first, then I experimented with value of discharging cap till pop was acceptable.
Its extremely easy just to put resistor on output jack inside.
- Headphone Systems
- A damn bump in a Douk Audio U3
