a crazy idea (?) for volume control in DAC
Hello,
In a new AD1865 based DAC, I'm thinking about volume control, but not in the traditional way. What if I would build a 24 step step 200 Ohm log "pot" and use it as I/V resistor before the triode preamp?
At the moment I use 200 Ohm resistor, but as I know if I reduce the resistor, the voltage over the resistor will drop. Can I reduce to zero?
Problems I'm thinking about:
  • the resistor will be more "complex". Even if I do not put the resistors in series, but connect all to ground on one end and select single resistor. As I see I should be able to pick from E96 line. Does a little additional inductance matter here?
  • the resistors (or the selected resistor at a given setting) will not be a tantalum or caddock or similar, only ordinary metal film resistor. I do not know how much difference it makes. Maybe I loose more here than what I gain with the lack of volume control later
  • during switching, the resistance will go high momentary, resulting loud transient noise into the amps.
I'm wondering did any of you experimented with this?
Thanks,
JG
I've also given DAC volume controls considerable thought and ended up with likely the same (or perhaps similar) idea as you. Tap the I/V resistor at 1 or 2dB intervals and switch between them. In fact I have already implemented such a scheme on an earlier DAC design. Since I have an LC filter prior to my I/V resistor, I can't just lower the R to reduce gain as that'll upset the termination of the filter. Hence a tapped attenuator - I used 74HC4051s to build the mux, having around 60ohm on-resistance. Seeing as they're cheap they could be paralleled I guess to lower the on-resistance.
With your I/V resistor of 200R, this makes a very low noise volume control provided your switches are also low on-resistance.
Reactions: Giordano
