• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
7N Ohno cast mono crystal wire
zero sampling CD player , DAC24/192
Dugood DAC3 24/192 DAC present high resolution, wide sound staging. It's good for DAC that perform well with system that lacks refinment & sound staging.
set comes with a free optical cable
Glory year 16 bit CD player (zero sampling)
Bring back the glory of CD player 16 bit zero sampling CD player using TDA1541A. (same DAC chip use by Zendan). The most musical CD player. Vocal is organic with deep control bass.
The output using op amp without the coloration of tube with
good speed & transiant. If you are looking for this criteria , do not miss it !
Sounds analogue, close to LP.
This CD player can be used as :
a stand alone transport using philips mechanism VAM1201.
a stand alone DAC zero sampling TDA1541 (hi end Zenden
use this chip) using an external transport that you like most.
& a CD player
Model : Boundless, uses the PCM1702 DAC
Purchase any of the above , and pay another US$64 for the
pure silver Neotech NEVD2001 (usual is $96)
www.stereotimes.com/cable101805.shtml
www.dugood.com
www.neotechcable.com
www.ahfartaudio.com
zero sampling kit & preamp kit set
Preamp Permalloy Transformer
5K Ohm to 600Ohm
Finished in shielded copper and wood potted.
Refine highs, engaging vocal.
For use with WE417, 6922 , 5687 tube
Preamp kit set
Ma*tis Fantasy , Ja*is JP 200, Ca*y preamp kit set
in high quality PCB.
Zero sampling DAC kit (Sing$160 only)
Kits comes with
The main PCB with CS8412 chip, TDA1541
One LPF PCB using op amp
One LPF PCB with tube socket & tube 6N1
One brown dog adaptor
three RCA plug.
www.ahfartaudio.com
