Anyone done anything with a 6n7gt?--I was looking to use it as a driver for a couple of pl/el509 valves, and want to be able to drive the grids positive (AB2?), in an OTL (Sweep Tube Monoblock)
Would this valve replace a 5687 for this sort of highish power job?
Any views on if this valve is any good as to sound or distortion? I cant find much about it save its specifications!
Thanks!
Thanks!
6N7 but not gt
The first amp I built uses a 6N7 as the volt amp/floating paraphase splitter. It is run in the low current Class A mode seen on the datasheet. It sounds great, no reservations at all.
I also have a late forties Stromberg-Carlson 6L6 amp that uses the 6N7 as the driver. Sounds very nice as well. Haven't tried the glass tube though.
Michael
Michael
Did you run it with both sections in //?
Cheers,😉
Cheers,😉
I've used a 6N7GT (sections in parallel) to drive 10Y and 45 power stages. Very sweet sounding tube. I don't know about supplying power to a grid, though. You might want something with a lower Rp.
I think these are quite useful for a push pull circuit, they could be great in a long tailed pair.
Most LTP circuits call for the cathodes of the driver triodes being connected together with a resistor to ground, in a 6N7 the cathodes are internally connected so its ideal..
I have a NOS sylvania, i have struggled to use it anywhere tho.
In the amp I plan, it will be in a cathode follower arrangement, driving the grids of the '509 o/p tubes, the sections of each (2) drivers tubes will be parralleled off anyway and will drive 4 x '509 each. 8 x '509 in total
phase splitter
Hi Frank,
No the sections aren't in parallel. I am using it as a phase splitter. Will post the schematic and a picture in a new thread.
Michael
Hi Frank,
Michael
- Tubes / Valves
- 6n7gt
