There are lots of 6L6 class A single end circuits. We designed this special circuit which used the classic pentode tube, 6SJ7 as voltage amplifying stage and drive 6L6 or 5881, with tube rectifier 5Z4 or 5Y3. The output power is 6.5W in pentode connection of class A. It is powerful enough to drive loudspeakers at and over 87 dB. It well-matches Mark Audio full range drivers like CHR-70 and Alpair 7.
Specification:
AC input: 220V
Power output: 6.5W
Output impedance: 4 & 8 ohms
3 signal inputs
Frequency Response: 25Hz - 30KHz (-1 dB)
Power consumption: 80W
Dimension: 340W x 230D x 160H mm
N.W.: approx. 10KG
Special Price: USD290.
Specification:
AC input: 220V
Power output: 6.5W
3 signal inputs
N.W.: approx. 10KG
The output transformers for 6L6 single end:
Output power: 13W
Frequency response: 20Hz-25KHz
Primary impedance: 3.5K
Secondary impedance: 4 ohms and 8 ohms
Choke: 10H/300mA
Output power: 13W
Choke: 10H/300mA
what's shipping to US?
Let me check the shipping cost.
Thanks.
Tony.
The shipping cost from Hong Kong to USA is around USD180 via Speedpost.
Thanks.
We selected CELM 0.47uF/400V film capacitors in coupling between 6SJ7 and 6L6. Cathode capacitors are Philips BC 100uF/100VDC. The caps make sound of the amp transparent and detailed.
Are you saying that it costs $180???
The shipping of the amplifier (GW 14KG) from Hong Kong to USA costs around USD180 via Speedpost.
The voltage of this amplifier is 220V.
Thanks.
Thanks Alejandro. I will send it out within this week. Hope you will love the amplifier.
Cheers.
Tony.
Cheers.
Tony.
We can re-make this 6L6 amplifier in the similar circuit, the new price is USD530 as the cost of the most parts like transformers had increased, and USD290 is our very special sales price.
Cheers.
Cheers.
Hi Alejandro,
Yes, you can change those Chinese tubes with some NOS tubes:
6P3P can be directly changed to 6L6, 6L6GC or 5881
6J8P can be directly changed to 6SJ7 in glass or metal cover
For the recitifier, can use 5Z4P, 5U4G, U52, 5R4G, 5AR4, GZ34, 5Y3......
Thanks.
Tony.
Thanks.
Tony.
Do you recommend changing the chinese tubes with N.O.S ?
- More Vendors...
- Twin Audio
- 6L6 class A single end amplifier
