6J1 Preamp
Just got a 6J1 buffer preamp in the mail. Its the Little Bear preamp that uses 6J1 tubes. Cost was $30.
The Chinese 6J1 tubes are squishy sounding. After replacing them with USA 5654 tubes it came alive and sounds really great going into a solid state amp.
Looking at the schematic, the tube section is above ground, fed with +28 and -28 volts from a split rail supply.
Is this a way of getting a plate voltage of 2 x 28, or 56 volts on the plate? Or does it not work that way?
You have +/-28 volts on plate available.
Would have thought the half wave filtered power to the filaments would cause more hum/buzz trouble than just the plain AC. Just would have supplied them direct in series or full wave rec.
