Hi, are there any Japanese-speaking (or, rather, Japanese-reading) forum members who would be able to translate some bits of the Toshiba 6GB8 tube datasheet? I have a handfull of used ones, they look good at Pa 35W, Pg2 10W, 130W from a pair in AB1, and I'll be happy to trade a couple of them for a translation of at least the non-guessable parts. I attach a part of the data sheet, at the moment I'm particularly interested in what seems to be SE pentode operation at 250V (p1, LH column) yielding 15W, but I can't figure out what is 20 m-ohms, what is 15K ohms, and what is 15 (the line above the 1,600ohm load). But I'd like also to understand the 320V/40W p-p and what seems to be the triode operation on the lower right. The power-crazies amongst us may be interested in the fixed-bias p-p figures.
please pm me if you wish
cheers from New Zealand
rtch
rtch
I can start the translation, at least:
The regime is "Single A1" and Application: (can't read it)
- The 20m Ohms is given as the Transconductance so a think they mean 20m Mho (20mA/V);
- the 15K ohms is "Plate inner resistance", i.e. Ra
Next, "Push-Pull AB1"
Va=Vg2=320V
"cathode resistor": 60 ohm
load: 2500 ohm
Table, first row: "Grid 1 signal input voltage rms"
2nd row "plate current"
3rd row "grid 2 current"
4th row "output"
5th row distorton
Yes, the last application has "2nd grid bound to plate"
etc
Then, the triode-mode PP mode is given.
Va=Vg2=320V
load: 2500 ohm
4th row "output"
5th row distorton
etc
Thanks, Rod, would you like a couple of used ones to play around with, if I can figure out how to safely get them to you from NZ?
Hello Rod. Would you be so kind as to translate a single end section?
Thanks in advance!
Andrew.
OK, it says
Single Class A
Va=Vg2=250V
Vg1=-8V
Cathode Resistor 57Ω
Internal Plate resistance 15KΩ
Output Load 1600Ω
G1 Drive V ... Plate Current mA ... G2 current mA ... Output W ... Distortion%
0V .................... 140.................... 12 ................... - ................... -
3.2 V ................. 145 ................. 16 ................. 6 ................. 5.8%
4.65V ................. 149................. 21.5 ............... 12 ................. 8.1%
3.2 V ................. 151 ................. 28 ................. 15 ................. 9.5%
それらのPenthodesをお楽しみください!
ロッド
Enjoy those Pentodes! -Rod
Thank you guys!!!
I have one more question if you don't mind.
Are a driven voltage of G1 in RMS or peak value?
Many Thanks!
Andrew.
Many Thanks!
Andrew.
- Tubes / Valves
- 6GB8 data sheet translation needed
