Used in a differential, cascode (Hedge) configuration. Been leaving it open "floating" so far. But it is there!
THANKS
THANKS
If you’re not having any hum or crosstalk issues don’t mess with it. If you are then ground it directly to signal ground.
If you leave it floating you can get weird distortion effects. Just ground it.
- Tubes / Valves
- 6DJ8 - What do you suggest I do with pin 9 (shield between sections)?
