6ch. volume control + attenuator for DCX2496 on the cheap
I've got a DCX2496, and I'd like to attach a six-channel volume control / attenuator box so that I can get the maximum dynamic range out of it. Instead of using the standard PGA2311 digitally-controlled volume pots, I was thinking of using three stereo 16-step make-before-break attenuators mechanically ganged together in combination with six op-amp amplifiers with the gain set to compensate for the varying sensitivity of each driver.
Is this an advisable solution?
