Hi There
I need some 6800uf to 10000uf caps. Screw-In type. 100V
4 or 8 ,I'm not sure yet.
Let me know what you have.
Thanks 👍
Thanks 👍
Not sure what you mean with screw-in. Once there were electrolytics with a central 18 mm plastic thread for fastening, but I never saw one with your specs. Or do you mean screw terminals?
Best regards!
Best regards!
I've got 75mm height to work with. I can't find any that will fit.
Originals are Cornell Dubilier DCME1398.
That means screw terminals, not fastening screws, right? I guess you need replacement electrolytics with the same outer dia, but not taller than the originals?You screw them in underneath. machine screws. Negative and positive.
Best regards!
Yea Man.
I thought they were making caps smaller not bigger.
You can get ones that fit but not screw terminals.
I could get Snap in ones and bridge it over with thick wire.
I didn't want to do that but it looks like thats one of the options I have.
You can chose from 18 different 6.800 µF 100 V aluminium electrolytic capacitors with screw terminals at Mouser.com. So, what's the problem?
Best regards!
Best regards!
Didn't go into the details there, but really nothing available at Mouser's? Not even 8,200 µF or 10 mF?
Best regards!
Best regards!
Yea man unbelievable. I'll have to go with snap in.
Ive tried them all CPC ,Farnell ,Digikey ,Mouser ,RS Components.
The problem now is the ripple current. The snap in ones can't handle as much as the big screw in ones. Best Screw in that was close ,was Kemet ,14.4A ,It was just too tall at 107mm. Highest Snap-in was 6.6A. Theres a fair few that are not in stock aswell.
The only other option which i doubt I'd do ,is to make a bigger Lid for the Amp. So I can get the biggest caps I can get in there.😎
The Amplifier is a Crest CA4.
I got some caps anyway. 10K 100V.
Cheers
Cheers
I got these ones for anyone in the future looking at what to replace the caps with.
https://uk.farnell.com/kemet/alc70a103eh100/cap-10000uf-100v-alu-elec-qc-snap/dp/2950146
A bit of jiggery pokery and I got them to fit.
40mm vs 36mm.
40mm vs 36mm.
The Amp is going into protect when I turn up either of the volumes. Seperately. The fans speed up aswell.
They come out of protect when I turn them back down.
I'll try again tonight and see exactly what its doing. Lights etc.
Cheers
Cheers
