6 ohm speaker 8 ohm amp
Would it be possible to run a 6 ohm speaker on an 8 ohm amp?
You don't have an 8 Ohm amp...
What you have is an amplifier with a power rating into a given load, often measured as 8 or four Ohm.
A transistor amp with a given power rating for an 8 Ohm load will produce slightly more power into a 6 or 4 Ohm load and so on.
Lemme guess, this is one of these TXxxx range hometheatre amps from JVC?
Cheers,😉
