Hello.
I was woundering if anyone have built a 6-channel amplifier? The only picture I could find on this subject is the one found at www.aussieamplifiers.com, but his amplifier is not awail for the moment. 🙁
Could anyone please help me to find schematics or PCB-files to an anmplifier like this?
HFosse
HFosse
This is the link to the amp you are refering to:
http://www.aussieamplifiers.com/downloads/AV800.pdf
Complete construction manual with everything except the PCB layout. You can probably order PCBs from Mr Holton.
/Marcus
/Marcus
Joined 2002
YUr a moron the guy simply said 6 CHANNEL not anthonys av800 he is refering to the main amp on his page the 6 channel on one board..
NOw i was going to build a 6 channel amp i was going to make it with 6 of the hitachi lateral amps 1kva toroidial with 6 boards...
mabey some day..
mabey some day..
Joined 2002
I am in the process of working on a 6 channel leach amp. It will use my new pcbs that I designed, but have not had made yet ( http://brian.darg.net/leachamppcb/aar ), and be enclosed of a chassis made out of two of heatsinks (
http://brian.darg.net/aleph/aab ) as the sides of the case (8" x 9" x 2.6") and the final dimensions will be 17" wide, so it can fit in a rack, 8" deep and 9" tall.
I might have to use 3 heatsinks for the case, with one in the front. It depends on how cool they run with 3 channels on them. My current leach amp runs very cool with its heatsinks that are quite a bit smaller:
http://brian.darg.net/leachamp-2channel
They barely get warm to the tough, and weigh less then half the weight of one of the big heatsinks.
Brian
Brian
- 6-channel Amplifier
