Hi all,
As some may know I have been modifying quite drastically my DCX2496 (see link below) and I came to a point where I realized I badly needed a 6 channel volume control (I'm now using the DCX the "right way", i.e. through digital input)
As market does not offer many "audiophile" solutions I asked a french company if they could invest some time to study such a device, and they came back to me with this :
I thought it would be interesting for you DCX2496 owners to know that an alternative solution is now available.
Cheers
Thierry
a picture says it all :
Visit my website : Tweaking the DCX2496
Cheers
Thierry
Since this unit is designed for the DCX why no XLR inputs?
It would be nice to have XLR inputs and both XLR and RCA outputs..
--Chris
--Chris
Yeah, analog or digital inputs would be nice. I think I may try the 8 channel mic pre-amp, ADA8000 as a gain control for my DEQ / DCX system to set relative levels of all 6 channels.
- James
- James
You may want to shoot me an email reminder in 2 - 4 months. It will be that long before I have time & money to try it.
- James
- James
What type opamps do they use?Thmartin said:Hi all,
Hans.
You may want to look into this -
http://www.sle.se/products/v8pro/
Designed and built specifically for this application. They've been working on it for a while. Should be available soon.
Re: Re: 6 ch. vol. control for DCX2496
They don'use opamps, they use 2SJ74, 2SK130 and 2SK30 FET transisors.
The assembling procedure is described here : Kit instructions
Volume control is available as a kit or as a ready to use unit. Check here : Special offer
Cheers
Thierry
Hans.
Cheers
Thierry
Re: Re: Re: 6 ch. vol. control for DCX2496
... Maybe something to try out later as it look like it could be a nice upgrade from the Altronics kit.
That all looks very nice indeed! It's too bad my K5600 kit arrived two days ago by mail... Go figureThmartin said:
Cheers
Thierry
This is interesting, and I also would be pleased to see some explanations in English, if this is possible.
For example, there appears to be 6 pairs of RCA connectors on the rear.
Assuming two of these (one pair) are for a stereo input, how does the remaining 5 pairs relate to six channels?
I wish I could read French better!😱
Edit: I've just realised what a silly query this is, as, of course there are 6 inputs and 6 outputs! But some more detail in English would be very helpful.
Regards,
Regards,
Time for me to show my translator skills!
Niveau de chaque canal ajustable pour harmonisation en fonction de la sensibilité des amplis utilisés
• Technique audiophile exclusivité Selectronic totalement neutre et transparente (buffers d'E/S à FETs)
• Potentiomètre ALPS motorisé
• Condensateurs de filtrage TFRS, etc.
• Circuit imprimé double-face avec vernis épargne
• Le grand luxe habituel
Adjustable channels according to amps sensitivity (+/-3db)
Selectronic exclusive totally neutral and transparent audiophile technics (FET I/O buffers)
Motorised ALPS pot
Very low FRS capacitors used in the PS
Double sided PCB with vernis épargne (?)
The usual top quality (!)
As for the price:
Assembled kit in 1U rack with remote control = 399€
Remote kit (no rack) = 239 €
Basic kit (no rack, no remote) = 199 €
Special offer until 19 june 2006 : A rack is given with the remote kit
Voilà!
Motorised ALPS pot
As for the price:
Voilà!
Hi kepa1,
Thanks a lot for this mini translation, you are very kind.
It is over 50 years since I left school, and I remembered some things like "en ordre de marche", which I believe literally means "ready to go"! 😀
Regards, et merci.
Regards, et merci.
Très bien Bob, tu as quelques restes!
Pour approfondir tes connaissances en français, voici un peu de lecture concernant l'alimentation dediée au dcx2496 proposée par Selectronic (en ligne d'ici peu).
Merci kepa1,
Mais j'ai une petite problem.
"To have a more thorough understanding in French, here are a few words concerning the sale *dediee* (c'est dedicated?) to DCX2496 suggested by Selectronic (a small line here?)".
Je recherche mon dictionnaire, je pense!😱
Hello Bob,
Funny because you even write French with an English accent, very pleasing!
As for "dédiée", you are right. In fact, they designed a power supply that gives quality current to the AKM chips only, so you basically don't touch the stock PS... Soon to be avalaible on the site.
Cheers
Cheers
- Digital Line Level
- 6 ch. vol. control for DCX2496
