5902 amp schematics?
Hello. I'm interested in building an amp using two 5902 sub-mini tubes.
I'm having some trouble finding schematics of amps using these tubes. I would like to run them push-pull, cathode bias.
Any and all info is welcome.
Thanks,
Anthony
Alexander, thanks for posting those links.
I have been using a 955 (acorn) driving a P-P 5902 triode connected to drive a Klipsch La Scala for a few years. However both driver and power tubes are battery biased, 1.2V and 6V respectively. I use the small Hammond 125C as outputs. I don't have a schematic to share but my B+ is 110V. Nice sounding amp and I've been meaning to play around a bit more with it--also try a pentoded 5902 as a driver. So by all means dive into your project.
Matt
5902 push-pull amp from Italy
Folks,
If I may add a link on 5902 amplifiers: there is a push-pull amplifier project posted on the "Radio di Sophie" site, run by Italian hobbyists. I have built a prototype (single channel) of Nicola del Ciotto's amplifier and it sounds good, but needs a preamp capable of providing 10V RMS output (or more).
The following document provides all information including PCB layout:
http://www.leradiodisophie.it/Download/Nicola-del-Ciotto-Amp5902.pdf
(If anyone wonders: Sophie is (or was) an Abessynian cat with impressive looks, that liked to sit on working valve radios !)
Best regards,
Aren van Waarde (aka arensattic)
