Is it possible to use 5% restisters (R1-R8) for the SOZ or is absolutly necessary to use the qualities (1%, 0,1 %) mentioned in the NP article?
regards
Günter
regards
Günter
To obtain a low diffrential dc off set you need resonable matced resistors. You can parallel the higher values with some resistor to match the lower value. The formula for this is R=1/((1/R1)+(1/R2)).
Henrik said:To obtain a low diffrential dc off set you need resonable matced resistors. You can parallel the higher values with some resistor to match the lower value. The formula for this is R=1/((1/R1)+(1/R2)).
Or ... R = ( R1* R2 ) / (R1+ R2)
thank´s for you answer.
Are 25 Watt enough for the resisters R1-R8 to build a 10 Watt SOZ? For this values I can find 1 % resistors.
regards
Günter
regards
Günter
