Hello everyone ; Would the 4U enclosure stocked in the store have sufficient heat sinks for construction a F5C > P-F5c-2V20 - Pair of F-5c boards (Makes 2 channels; Rev 2.0) - Boards
If you will run the F5C in stock bias then yes it is more than enough. I am running an F5 in it's max bias setting and only get about 42*C, the ambient here is around 27*C to 28*C.
If you will run the F5C with a higher bias, that means you will need a bigger power supply and that may be a bit tricky to put together inside a 4U.
