4ohm amp to 8 ohm sub question
Hi, i have just brought a amplifier thats rated at 4ohms, i was thinking of using a peerless xls10, which is rated at 8ohm, can i connect this as it is or shall i use a 4 ohm resistor in parrallel?
which method would be the best?
also will the resistor get very hot and possibly brake, causing damage the amp or sub?
thx Olly
