4- vs. 8-Ohm woofers for this design
I’m planning for a new project of 2.5 ways triple woofers floor-standing loudspeakers. I wonder whether I should use 4 or 8 Ohms driver for mid & woofers.
There’re two options I could figure out:
I) Using 8 Ohms drivers
Speaker A will be 8 Ohms
Speaker B will be 4 Ohms, formed by two 8 Ohms connected together in parallel
II) Using 4 Ohms drivers
Speaker A will be 4 Ohms
Speaker B will be 8 Ohms, formed by two 4 Ohms connected together in series
Alternatively you parallel 2 * 4R drivers and cascade them to the third 4R driver though a large inductor. Size the large inductor around the baffle step frequency and a nice easy 6R load for the amplifier. Keep the DCR of the inductor as low as you can
Reactions: presscot
