4-lead ERO Roederstein KP
It's a low-inductance design probably for switchmode power supplies and such. Usual connection is for the unfiltered input to get one pair on one side and the filtered output pair on the other side. An ohmmeter will tell you which leads are connected together. I used a similar cap in a friend's old Counterpoint preamp along with a replacement switched volume control; the improvement in detail was very noticeable.
