4/8/16 Ohm Dual Dummy Load
I had a reason to drive a modest power amp into clipping in a dummy load and I came up with this. Those are not
low inductance resistors, just wirewounds by Ohmite but they can tolerate 100 watts into 8 ohms, 200 Watts into
4 or 16 Ohms. The channels are totally independent so it can be used with nearly any amp. The shorting plugs are
captive so they don't get misplaced. All the resistors are 16 Ohm 50 Watt. It's not fancy but is useful now and again.
The highest power I ran into it was 1 KHz sine 130 Watts/channel at 4 Ohms for 10 minutes. It was not
too hot to hold but it was getting there. It has a modest amount of thermal mass but not much thermal
radiation (no fins). Sine RMS is the most demanding as it is continuous (crest factor =1). Music RMS is
far less demanding of the dummy load.
