Hi Guys ,
i am making a 3 way active mini tower with side firing subs , using drivers available locally here in india , I dont have the mic to get the frd files needed for them and only viable option currently is to spl trace the drivers can any one help me with the frd & Zma files, please find attached datasheets of the drivers and baffle dimensions & placements
Hi. Neat looking sketch.
You're asking quite a lot there. Imo you should really invest in the tools to do this properly rather than approximate.
Have you looked in to diy measurement mics? Do a search, the capsules are cheap.
Designing is a lengthy process if you want to get it right and best not done blind/deaf.
