I have just programmed a crossover on this DSP board. I am powering the unit from a 5V supply via the micro USB. However once I disconect the USBi unit from the PC, I get nothing out, even though the 5V supply is still on.
Does the supply have to be via J19?
I have left the question so that others might not make the same mistake. When you are in editing mode using Sigma Studio, the softwar has control of the module via USBi. If you want to run the module stand alone, you need to power cycle the unit so that your software is loaded from the E2Prom.
I have left the question so that others might not make the same mistake. When you are in editing mode using Sigma Studio, the software has control of the module via USBi. If you want to run the module stand alone, you need to power cycle the unit so that your software is loaded from the E2Prom.
So it does not matter which power option you use as far as I know.
