The company I work for has around 300+ brand new old stock of Avel Lindberg Y236602 transformers for sale.
I just listed them on ebay at $45 each, obo. Here's the Ebay link Our goal is to find someone to take most or all of our stock and we will be willing to cut an amazing deal to make some space on our shelves! Even if you want a few, make an offer, we want to move them!
We also have some other DIY stuff, including MANY TBA7293 IC amplifiers (also listed on ebay), IRFP450 transistors (50 available), IRFP9240 (50 available), IRF510 (73 available). We also have a bunch of IEC power conectors with integrated fuses and some working and/or non-working plate amplifier panels (for install in speakers to make them self powered) using the above components. These originally went under the name PPA and some of the amps were also sold in Truth Audio monitors. We have lots of old boards and stuff for them, some can be DIY projects to make it work and others already work and just need installation.
Our new products we are developing include DSP and high power plate amps from Pascal audio. We have our own in-house designed interface for dual-input (xlr) or single input w/thru (xlr) that allows 4 dsp (or analog filters / limiters on boards tba) or use without any filterboard it has a couple of onboard filters available; all busses can be internally routed to any amp channel (up to 2x 3-channel digital class amps) as well as an external XLR output for jumping to another cabinet! We use THAT InGenious op-amps for all our inputs to preserve the highest audio quality (even with improperly balanced loads!), and a digital push-button/LED display with non-volatile memory for DSP mode (up to 4 dsp programs to be recalled from the rear panel) or polarity flip if there is no dsp installed! These are almost ready for production so please enquire if your interested! We have been using the amplifiers and dsp's for a couple of years in our own products for live production use with great results, now we are starting to market them to the public!
We also have some of our original dual-18" subwoofer boxes (6th order bandpass) that we are looking to move, as we have a newer slightly refined version we are making. They are large (4ft x 2 ft x ~<3'), heavy boxes (pretty standard for pro use) and have seen a number of shows but holding together well. We have been using them with B&C SW115-4 drivers as well as B&C NW100-8 drivers, with our amplifiers. At this point we can sell the boxes unloaded or with new or newly reconed NW100-8 drivers. Amplifiers will be ready soon, or we can retrofit a NL4 connector on the back (wire speakers either individual or parallel, however you want it). With our dsp, we have achieved FLAT response from 30hz to 120, and usable to 25hz! Just 2 boxes with our amplifiers (2400w x 2) will make your vision blur from 15 feet away! We have 8 to sell as is, unloaded, with paint on them ($800), and another 6 we can sell with bedlined finish for slightly more $. If you want we can get the non-bedlined re-done with the bedlined finish, but to do it right we need to really fix up the cabinets before they are sprayed so it will cost additional $ but they will really look brand new. Contact me if you're interested in any of our offerings! I can send pics if you want. We also have some other high end audio electronics for sale (Drawmer comps and gates, KT Helix system or quad gates, ARX EQ's or comps, BSS omnidrive install, Peavey Mediamatrix system, etc...) We are located in Pensacola Fl if your in the area you can come check it out first hand.
